Small glitch in patch.sql (Zabbix 1.4.2)
  • JacobF
    • Oct 2007
    While upgrading from 1.1 (Ubuntu Feisty Server) to Zabbix 1.4.2, I encountered a small glitch in patch.sql
    On line 695, the code reads:
    --insert into rights_tmp select * from rights
    When trying to import patch.sql through PHPMyAdmin, you'll get an error. The solution is quite simple: place a space between '--' and 'insert':
    -- insert into rights_tmp select * from rights
    After that, the patch imports without a hitch...
    Just my 2 cents,
    Sincerely,
    Jaap
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Thanks, registered as ZBX-95.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Fixed to make it work with the PHPMyAdmin, if anyone is interested...
      Alexei Vladishev
      My Twitter
