Security problem in Webfrontend (Zabbix 1.4.2)
  • qix
    • Oct 2006
    • 423
    When installing Zabbix 1.4.2 web frontend, step 4 "stars" out the database password and makes it invisible for people looking over your shoulder. However, page 5 (after the connection check), shows it in plain text.
    I think this behavior is not something you would want.
    Either show the password in screen 4 so the user knows he has to be cautious, or (better) remove the password field from step 5.
    With kind regards,
    Raymond
  • cstackpole
    • Oct 2006
    • 225
    I agree. That surprised me quite a bit when I saw it in plain text. Glad no one was around at the time...
    • qix
      • Oct 2006
      • 423
      Alexei,
      Can you fix this in the next release?
      With kind regards,
      Raymond
      • Aly
        ZABBIX developer
        • May 2007
        • 1126
        Thanks for reporting that.
        Fixed in rev. 4954.
        Zabbix | ex GUI developer
        • qix
          • Oct 2006
          • 423
          Thanks for the fix!
          With kind regards,
          Raymond
