Request: Active agent remote command execution
  • Valiant
    • Nov 2007
    Would it be possible to add remote command execution for active mode agents? The commands could stay in a queue until the agent "calls home" and downloads it. I deal with a lot of active agents behind firewalls and this would be a huge timesaver!
    Thanks a lot for a great product!
  • gospodin.horoshiy
    • Sep 2008
    • 272
    Would benefit greatly from that, so I sign here
    Zbx 2.0.4 on Debian and MYSQL5 on Ubuntu Server 64bit 8.04,
    200+ Win Agents, 50+ Linux Agents, 150+ Network Devices
    • maruscya
      • Jul 2007
      • 129
      Hello !!
      I ask this function some mouth ago...
      I hope that developer include this feature in the next version..
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        This is in our TODO list.
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
        • maruscya
          • Jul 2007
          • 129
          Thanks !!!
          Alexie your support is incredible. !!
          • gospodin.horoshiy
            • Sep 2008
            • 272
            Is there any progress on this feature?
            Thnx
            • elvar
              • Feb 2008
              • 226
              Thnx
              Yeah I could really use this as well.
              • tof233
                • Nov 2010
                • 94
                I just tried to execute a command (as an action on a trigger problem) with version 1.8.4 and it seems it doesn't work on Active mode.
                I changed the item associated with the trigger to Zabbix agent Active
                And I noticed that when I disable PassivMode on Zabbix agent, the item is still normally refreshed but the remote command is not executed. It only works when I enable PassivMode.
                So is this feature really implemented on the last Zabbix version?
                ps: I think that this problem is the only limitation on ActiveMode on Zabbix agents.
                • fire555
                  • May 2011
                  Any progress?
                  Just wondering if there has been any progress to this issue. It was formally lodged as a feature request here (https://support.zabbix.com/browse/ZBXNEXT-297) some time ago.
                  This would make the active agent incredibly powerful.
                  In the mean time, has anyone been successful with some kind of workaround? I can add a new item to run a remote command obviously this will happen periodically which is far from ideal.
                  Is there perhaps a way to disable template items for certain hosts by way of a trigger?
                  • nicola.pavlov
                    • Aug 2011
                    Any Progress?
                    Do we have any progress regarding this issue.
                    As stated by other users, such a functionality will really make active agents powerful.
                    Please advise.
                    Thanks,
                    Nicola.
                    • richlv
                      • Oct 2005
                      • 3112
                      as far as i know, it's not on the short term roadmap (https://zabbix.org/wiki/Docs/specs/2.0_roadmap)
                      • b00gz
                        • Jun 2014
                        Any update on when this will be implemented?
                        • thysk
                          • May 2013
                          • 21
                          Hi
                          Just wondering if this is coming any time soon, this enhancement will make a massive improvement to my monitoring environment.
                          T
                          • romale
                            • Mar 2013
                            • 53
                            Originally posted by thysk
                            Hi
                            T
                            +1 to this feature
                            • LenR
                              • Sep 2009
                              • 1011
                              #15
                              Having remote command relayed thru the hosts proxy would make life simpler also.
