Hi there,
as email sent by zabbix if some trigger is triggering I'm using something like:
just to get every possible information zabbix can give to me.
In all these macros I personally miss the macro TRIGGER.THRESHOLD that should tell me which was the threshold trepassed by the trigger: can you consider to add it? Does it make sense to you?
Is it also possible to have the real trigger expression? Say I have an item defined as
and the trigger is
how can I get this expression? Is it possible to add the macro TRIGGER.EXPRESSION as well?
Many thanks for your wonderful work!
Bye
Piero
{TRIGGER.NAME}: {STATUS}
{TIME} {DATE}
{HOSTNAME}:{IPADDRESS}
{EVENT.ID}
{ITEM.NAME}
{ITEM.LASTVALUE}
{STATUS}
{TRIGGER.COMMENT}
{TRIGGER.ID}
{TRIGGER.KEY}
{TRIGGER.NAME}
{TRIGGER.SEVERITY}
{TRIGGER.STATUS}
{TRIGGER.URL}
{TRIGGER.VALUE}
system.cpu.load[,avg1]
{Template_Linux:system.cpu.load[,avg1].min(900)}>5.5
Bye
Piero
