Hi People!
The zabbix is very good tool for monitoring! I have many hosts monitoreds.
I am need monitoring one router, just test of ping (for test your availability).
Follow my confs:
Configuration of host:
Name: router-20 (virtual name)
Group: Routers
IP address: 200.20.25.30
Connect to: Ip address
Port: 0
Status: Monitored
Item linked in router:
Description:Test availability of router
Type: Simple check
Key: icmpping
type of information: Numeric float
Use multiplier: Do not use
Update interval (in sec):
Status: Active
Store value: As is
The Simple check not e work; the message error is present:
Cannot connect to [200.20.25.30:0] [Connection refused] by UI
Get value from agent failed. Error: Cannot connect to [200.20.25.30:0] [Connection refused] by log zabbix-server.
Which port I use (in register of host)? for correct comunication?
I am using Simple Check, why not work?
Comment:
- My ping (fping) is worked fine which others hosts, but which agent instaled in remote host.
- Version of zabbix: ZABBIX Server (daemon) v1.4.4 (17 December 2007)
Compilation time: Apr 16 2008 16:26:04.
- In console of server-zabbix the ping is worked in the host created (200.20.25.30).
- I search this forum and read the manual (version 1.4), but not find the solution.
Help-me, please!
Follow my confs:
Group: Routers
Port: 0
Status: Monitored
Type: Simple check
Key: icmpping
Status: Active
Store value: As is
Comment:
Help-me, please!
