ur explanation is quite short....
did u perform some tests before posting ?
that is :
what is returning zabbix ? "not supported", "no data" ? did u try with a debuglevel = 4 ?
did a snmpwalk from ur zabbix server on this oid return a result ?
with all this tests, u may have a better look on the problem
