Zabbix server stops after 8 hours
  • Han
    • Apr 2005
    • 23
    Hello all,
    We are using zabbix 1.4.4 everthing is working well but zabbix is stops after 8 hours zabbix status is ok.
    When we gestart zabbix-server it works well again but puts stops after ca 8 hours.
    Hope anyone can help us.
    Kind regards,
    Han
  • xs-
    • Dec 2007
    • 393
    please paste the appropriate lines from the zabbix_server.log file
    It gives the reason and message why it stopped
    • bbrendon
      • Sep 2005
      • 873
      Also, you shouldn't post bug reports unless you're running the latest version.
      Unofficial Zabbix Expert
      Blog, Corporate Site
      • Han
        • Apr 2005
        • 23
        Zabbix stops running after 8 hours
        Sorry we are running the latest verion 1.4.5
        This is the zabbix.log
        29068:20080715:105426 Expression [{12740}>150000] cannot be evaluated [Unable to get value for functionid [12740]]
        29068:20080715:105426 Expression [{12860}>150000] cannot be evaluated [Unable to get value for functionid [12860]]
        29068:20080715:105427 Expression [{12920}>0] cannot be evaluated [Unable to get value for functionid [12920]]
        29066:20080715:105428 Expression [{12923}>0] cannot be evaluated [Unable to get value for functionid [12923]]
        29066:20080715:105430 Expression [{12743}>100] cannot be evaluated [Unable to get value for functionid [12743]]
        29068:20080715:105431 Expression [{12745}>100] cannot be evaluated [Unable to get value for functionid [12745]]
        29066:20080715:105435 Expression [{12748}>100] cannot be evaluated [Unable to get value for functionid [12748]]
        29066:20080715:105435 Expression [{12928}>150000] cannot be evaluated [Unable to get value for functionid [12928]]
        29066:20080715:105439 Expression [{12753}>1000] cannot be evaluated [Unable to get value for functionid [12753]]
        29068:20080715:105443 SNMP error in packet. Reason: (noSuchName) There is no such variable name in this MIB.
        • xs-
          • Dec 2007
          • 393
          I highly doubt these are the last lines after the zabbix server stopped.
          • Han
            • Apr 2005
            • 23
            I am posting in the name of Han (my name is Berry)
            I found out that the problem is similair to the following problem (same outputs /symptons):
            I guess it is fixed in the pre-zabbix-1.4.x version.
            But what is a wise decision?? Should we wait till maybe 1.4.6? or wait for 1.6 on 18 september? Or change it with the nightly builds?
            Kind Regards,
            Berry
            • xs-
              • Dec 2007
              • 393
              If you are sure that the 1.4.x-svn solves your problem, i'd try that. You dont need to replace the webinterface and stuff, just the server binary.
              So just recompile zabbix_server from a 1.4.x-svn checkout and 'try'.
              • Han
                • Apr 2005
                • 23
                Hey xs-,
                I followed your advice, at first glance it seems ok.. and i hope it won't happen again
                Thanks for your advice
