Zabbix 1.4.5
Oracle9i (9.2.0.8)
When running the script create/schema/oracle.sql the following errors occur:
What's up with that?
Changing 0.0000 to 0 does help.
But what to do with '99.9' ? Setting to '99' ?
Solution: Changing '99.9' to '99,9'.
Maybe it's because I use Oracle SQL Developer in a german language environment. And in German language the decimal point is a comma.
Oracle9i (9.2.0.8)
Error starting at line 163 in command: CREATE TABLE history_sync ( id number(20) , nodeid number(20) DEFAULT '0' NOT NULL, itemid number(20) DEFAULT '0' NOT NULL, clock number(10) DEFAULT '0' NOT NULL, value number(20,4) DEFAULT '0.0000' NOT NULL, PRIMARY KEY (id) ) Error at Command Line:163 Column:0 Error report: SQL Error: ORA-01722: Ungültige Zahl 01722. 00000 - "invalid number" *Cause: *Action: Error starting at line 171 in command: CREATE INDEX history_sync_1 on history_sync (nodeid,id) Error at Command Line:171 Column:0 Error report: SQL Error: ORA-00942: Tabelle oder View nicht vorhanden 00942. 00000 - "table or view does not exist" *Cause: *Action: Error starting at line 230 in command: CREATE TABLE history ( itemid number(20) DEFAULT '0' NOT NULL, clock number(10) DEFAULT '0' NOT NULL, value number(20,4) DEFAULT '0.0000' NOT NULL ) Error at Command Line:230 Column:0 Error report: SQL Error: ORA-01722: Ungültige Zahl 01722. 00000 - "invalid number" *Cause: *Action: Error starting at line 235 in command: CREATE INDEX history_1 on history (itemid,clock) Error at Command Line:235 Column:0 Error report: SQL Error: ORA-00942: Tabelle oder View nicht vorhanden 00942. 00000 - "table or view does not exist" *Cause: *Action: Error starting at line 272 in command: CREATE TABLE trends ( itemid number(20) DEFAULT '0' NOT NULL, clock number(10) DEFAULT '0' NOT NULL, num number(10) DEFAULT '0' NOT NULL, value_min number(20,4) DEFAULT '0.0000' NOT NULL, value_avg number(20,4) DEFAULT '0.0000' NOT NULL, value_max number(20,4) DEFAULT '0.0000' NOT NULL, PRIMARY KEY (itemid,clock) ) Error at Command Line:272 Column:0 Error report: SQL Error: ORA-01722: Ungültige Zahl 01722. 00000 - "invalid number" *Cause: *Action: Error at Command Line:602 Column:0 Error report: SQL Error: ORA-01722: Ungültige Zahl 01722. 00000 - "invalid number" *Cause: *Action
