I have what I hope is a rare problem. We haave to shut down our datacenter for high voltage power work. We were attempting to use zabbix to verify that all the systems were actually offline before shuting down the power. Howwever, as the number of offline systems increased, the response time for zabbix became slower to the point that it wasn't responding in a timely manner (eg: I shut the system down and 5 minutes later zabbix still had not recognized it as down). What should I change to avoid this issue??
Here is some data:
Number of hosts (monitored/not monitored/templates/deleted) 288 209 / 67 / 12 / 0
Number of items (monitored/disabled/not supported)[trapper] 29460 15555 / 3259 / 10646 [1]
Number of triggers (enabled/disabled)[true/unknown/false] 16394 8213 / 8181 [33 / 90 / 8090]
Number of users (online) 30 3
Required server performance, new values per second 211.6517 -
# This is config file for ZABBIX server process
# To get more information about ZABBIX,
# go http://www.zabbix.com
# This defines which server this is.
# Default value 1
# This parameter must be between 1 and 255
Server=2
# Number of pre-forked instances of pollers
# Default value is 6
# This parameter must be between 5 and 255
StartPollers=32
# Number of pre-forked instances of trappers
# Default value is 5
# This parameter must be between 2 and 255
StartTrappers=2
# Listen port for trapping. Default port number is 10051. This parameter
# must be between 1024 and 32767
ListenPort=10051
# How often ZABBIX will perform housekeeping procedure
# (in hours)
# Default value is 1 hour
# Housekeeping is removing unnecessary information from
# tables history, laert, and alarms
# This parameter must be between 1 and 24
HousekeepingFrequency=1
# How often ZABBIX will try to send unsent alerts
# (in seconds)
# Default value is 30 seconds
SenderFrequency=60
# Uncomment this line to disable housekeeping procedure
#DisableHousekeeping=1
# Specifies debug level
# 0 - debug is not created
# 1 - critical information
# 2 - error information
# 3 - warnings (default)
# 4 - for debugging (produces lots of information)
DebugLevel=3
# Specifies how long we wait for agent (in sec)
# Must be between 1 and 30
Timeout=15
# After how many seconds of unavailability treat a host as unavailable
UnavailablePeriod=240
# Name of PID file
PidFile=/tmp/zabbix_server.pid
# Name of log file
# If not set, syslog is used
LogFile=/tmp/zabbix_server.log
#Location for custom alert scripts
AlertScriptsPath=/home/zabbix/bin/
ExternalScripts=/home/zabbix
#Location of 'fping. Default is /usr/sbin/fping
FpingLocation=/usr/local/sbin/fping
# Frequency of ICMP pings. Defauls is 30 second.
#PingerFrequency=30
# Database host name
# Default is localhost
#DBHost=localhost
# Database name
DBName=zabbix
# Database user
DBUser=zabbix
# Database password
# Comment this line if no password used
DBPassword=z4bb1x
# Connect to MySQL using Unix socket?
DBSocket=/var/lib/mysql/mysql.sock
#DBSocket=/tmp/mysql.sock
UnreachableDelay = 30
UnreachablePeriod = 120
UnavailableDelay = 300
Any advice??
Here is some data:
# Default value 1
Server=2
StartPollers=32
StartTrappers=2
ListenPort=10051
# (in hours)
# (in seconds)
SenderFrequency=60
DebugLevel=3
Timeout=15
# Name of PID file
# Name of log file
#PingerFrequency=30
#DBHost=localhost
# Database name
DBName=zabbix
# Database user
DBUser=zabbix
# Database password
DBPassword=z4bb1x
Any advice??
