Zabbix-agentd deletes pid *directory*?
  • awmcclain
    • Aug 2008
    My daemon is set up to create its pidfile in /var/run/zabbix-agent/ in both /etc/zabbix/zabbix-agentd.conf and /etc/init.d/zabbix-agent (as per the default in zabbix-agent 1.4.1-2 in ubuntu gutsy)
    However, whenever the server restarts, the /var/run/zabbix-agent/ directory gets deleted! What gives? I'm tired of having to manually recreate the directory after every reboot.
  • troffasky
    • Jul 2008
    • 640
    Is this on Ubuntu by any chance? I had a similar problem, although MySQL corrupted all the .frm files before I managed to fix it.
    • luximinator
      • Jan 2009
      Zabbix pid - solution
      Good morning althogether,
      I got this problem on two identical Zabbix installations, too. They're both running under an Ubuntu 8.04 LTS Desktop, updated to 8.10.
      Everey reboot, the agent's pid-file gets deleted and you have to create this directory and file manually by console.
      So I had a closer look-up to my configuration, as Zabbix is already mentioned, installed in standard options: both conf-files had the correct path /var/run/zabbix-*/zabbix_*.pid.
      So there must be another mistake. Zabbix daemons should be started every system boot up, the log files show instead of this, server started but agent failed: missing pid.
      In this cases I got two kind of this problem. Just have a look at your Zabbix start skripts in /etc/init.d, there's a simple mistake in the code.
      Case 1:
      Agent's file:
      DAEMON=/usr/sbin/zabbix_agentd
      NAME=zabbix_agentd
      DESC="Zabbix agent"
      PID=/var/run/[B]zabbix-agent[/B]/$NAME.pid
      test -f $DAEMON || exit 0
      Server's file:
      DAEMON=/usr/sbin/zabbix_server
      NAME=zabbix_server
      DESC="Zabbix server"
      As you can see, both files got PID=/var/run/zabbix-agent/$NAME.pid as file path for the pid. Change the wrong one to the correct path and save the file.
      Case 2:
      set -e
      [B]if ! [ -d 'dirname $PID' ]; then
               mkdir -p 'dirname $PID'
               chown zabbix:zabbix 'dirname $PID' [/B]
      fi
      export PATH="${PATH:+$PATH:}/usr/sbin:/sbin
      case "$1" in
      In this case, in one of both files - here the agent's one for my second installation - there's missing a part (bold marked).
      Check your scripts and insert the missing part, save it and reboot.
      In both cases, wrong path and missing parts, and the solutions described here, my Zabbix daemons started correctly after reboot without any problems The procedure is also logged in the log-files, so you can check it.
      Have a try and post your experiences with my hints.
      Have a nice day
      Luximinator
      • troffasky
        • Jul 2008
        • 640
        See also:
        Can't believe this bug is still dragging on!
        • tekknokrat
          • Sep 2008
          • 140
          current 1.6.2pre packages contain a fix for this issue.
