Remote Command Action only shows In progress.
  • slrcblack
    • Aug 2008
    I am running 1.5.3. I have an action defined that runs a script. The script gets run correctly and it does work. But, on the dashboard.php page and on the tr_events.php page, it shows the status as In progress. It never changes.
    I turned up the logging and I see it sending back a response:
    1288:20080825:072154 Run command '/opt/ab/tools/zabbix/scripts/agent/bea.garbage.ksh XXXX'
    1288:20080825:072154 Sending back [1]
    Any Ideas?
  • loophole
    • Feb 2008
    • 20
    Can't realy help you, cause I'm havin the same issue. See http://www.zabbix.com/forum/showthread.php?t=10316. Maybe thats a bug. I see if i have some time on the weekend to get this further.
    • slrcblack
      • Aug 2008
      Thanks for the reply. I would appreciate any help you can provide.
      • slrcblack
        • Aug 2008
        Any Updates or ideas?
        Any help would be appreciated.
