Strange values on phpmyadmin using innodb (1.4.6)
  • txalin
    • Jan 2008
    • 31
    Hi all,
    As you can see here
    we encounter big problems with graphs, after performing some tunning on the database we increase the speed of the web interface by 200% as you can see on this screenshot:
    And here you have the my.cnf setup:
    key_buffer = 1500M
    max_allowed_packet = 16M
    thread_stack = 128K
    thread_cache_size = 8
    max_connections = 100
    table_cache = 1800
    thread_concurrency = 10
    # * Query Cache Configuration
    query_cache_limit = 100M
    query_cache_size = 99M
    So, now, we have a very very fast interface and everything seems to be going very very well, but there are a few very annoying things on database. With the issue of the database we installed on server a few tools for monitoring the database, mytop, mysqlreports and phpmyadmin. Here you have what phpmyadmin shows:
    This MySQL server has been running for 4 days, 22 hours, 31 minutes and 12 seconds. It started up on Sep 11, 2008 at 09:54 AM.
    Traffic______per hour
    Received 40 GiB______344 MiB
    Sent 61 GiB______523 MiB
    Total 100 GiB______867 MiB
    Connections__per hour_____%
    max. concurrent connections 54________---_________---
    Failed attempts 7,056______59.53______6.65%
    Aborted 42_______0.00 k______0.04%
    Total 106 k_____895.56_____100.00%
    Slow_queries 3,982
    Innodb_buffer_pool_pages_dirty 8,727
    Innodb_buffer_pool_reads 732 k
    Innodb_row_lock_waits 176
    Handler_read_rnd 91 M
    Handler_read_rnd_next 1,667 M
    Created_tmp_disk_tables 66 M
    Key_reads 8,020 k
    Opened_tables 233
    Those are the values showing as a problem, and also, using mytop the output shows that the key efficiency is just 22%. The biggest problem that i think we have is the "Handler_read_rnd_next" value and the "Innodb_buffer_pool_pages_dirty".
    So, my question, as i don't have any idea regarding database tunning, with this outputs, do you think that the tunning we perform is ok or we will encounter database problems in the future?
    I know that could be hard for reply to this question, so, thanks in advance for reading this
