we are currently setting up our JMX Monitoring using Zabbix 1.6 and the Zapcat 1.2 JMX bridge deployed on the monitored machines. Everything works quite well. One question arose: how can I configure zabbix to user JMX version 1.0? If the monitored server is configured to use:
-Djmx.serial.form=1.0
or uses an old JMX implementation (like BEA 8.1). If I activate the items every item shows "Not supported by ZABBIX agent". Deleting this option on the agent makes everything work fine. How to pass this option to the zabbix server?
Thanks,
Marek
Thanks,
Marek
