I'm trying to see if anyone has ran across a way for Zabbix to ensure that a vfs.fs.size check is checking against a partition or against the file system. Basically, what I have is some systems where /u is mounted from a SAN and some systems that have /u (not mounted, just created in the / space). I would like for the zabbix agent to report that /u is not supported on systems that /u is not a physically mounted partition rather than reporting pfree alerts just because it exists.
I know I can per system disable that specific check, but for ease of use, just checking to see if there is something that can be added to the template to differentiate.
Kind regards,
Patrick
Kind regards,
Patrick
