Graphid Oddities in v1.6?
  • dafyre
    • Sep 2008
    • 44
    Hi All:
    I have just discovered Zabbix recently, and it has been exactly the type of program I've been looking for! I have a VM that runs Zabbix 1.4.1 from the Ubuntu 7.10 Repos that works flawlessly.
    I saw the ugprade notice and decided to install it from source on a VM of Ubuntu 7.10. Apache 2.0.63, net-snmp 5.4.2,PHP-5.2.6, and Zabbix 1.6 (with MySQL support) have all been compiled from source. phpinfo() shows the bcmath module is included in my PHP installation (as is GD, and MySQL).
    I have one server (Windows 2003) that I've added in (the server is still running the v1.4 Zabbix Agent). I have added two items. One item is the CPU Load, and the other is Free Disk Space.
    The CPU Load Graph works as expected. However, FreeSpace graph does not want to work. It shows the free space at the bottom of the screen (ie: I can see the amount in the text). The graph count along the Y-Axis (on left OR right site) counts down instead of up. Instead of 14gb being at the top of the Y-Axis, it shows at the bottom!
    The graph looks like the Y-axis has been inverted. Even if I change it to be a fixed value, I still get the inverted Y-axis, and cannot see any data. Is this just a problem I'm having, or are others having it as well?
    Thanks!
    ~Brant
    ps: See the attached screen shot if you don't understand what I'm talking about.
  • tchjts1
    • May 2008
    • 1605
    I've experienced the same thing... but it was not for disk space, it was for memory. No matter how I changed the values or the axis, the high value was at the bottom of the graph.
    • Aly
      ZABBIX developer
      • May 2007
      • 1126
      Fixed. Thank you.
      Zabbix | ex GUI developer
      • dafyre
        • Sep 2008
        • 44
        Svn?
        Originally posted by Aly
        Fixed. Thank you.
        Hey Aly:
        I see in another post you said a similar problem had been fixed in the SVN repository... I cannot seem to find the SVN access instructions for Zabbix. Can you point me to them?
        Thanks!
        ~Brant
        • Aly
          ZABBIX developer
          • May 2007
          • 1126
          svn://svn.zabbix.com
          svn co svn://svn.zabbix.com
          • dafyre
            • Sep 2008
            • 44
            Thanks!
            Thanks for the help!
            • Alexei
              Founder, CEO
              • Sep 2004
              • 5654
              Note that the latest pre 1.6.1 package can be taken from www.zabbix.com/developers.php
              Alexei Vladishev
              New York | Tokyo | Riga
              My Twitter
              • dafyre
                • Sep 2008
                • 44
                pre 1.6.1
                Thanks for the tip, Alexei. I managed to find that one earlier this morning. I got the SVN version (which is 2 revs higher than the Nightly build)... and that seems to have fixed my problems. Now I just need to go add all my other servers in and see what happens.
                See Yas!
                ~Brant
                • markusz
                  • Oct 2007
                  same problem
                  I experience the same thing, but in the stable version of 1.6. It is a fresh install, nothing was migrated from an older zabbix.
                  Zabbix agent does return values, i can see them, but there is no line in the graph.
                  all other graphs are working (as far as i have tested). the item "free disk space in %" does work.
                  can anyone help?
