Database error in IT Services
  • jpilldev
    • Oct 2008
    Hello.
    I has been installed Zabbix 1.4 with PostgreSQL 8.3 in a RHEL5, with 1.6 had problems with the clients.
    Everything is fine but the IT Service Section shows me this error:
    * pg_query() [function.pg-query]: Query failed: ERROR: for SELECT DISTINCT, ORDER BY expressions must appear in select list[/var/www/html/zabbix/include/db.inc.php:275]
    * Error in query [SELECT DISTINCT s.serviceid, sl.servicedownid, sl_p.serviceupid as serviceupid, s.triggerid, s.name as caption, s.algorithm, t.description, s.sortorder, sl.linkid, s.showsla, s.goodsla, s.status FROM services s LEFT JOIN triggers t ON s.triggerid = t.triggerid LEFT JOIN services_links sl ON s.serviceid = sl.serviceupid and NOT(sl.soft=0) LEFT JOIN services_links sl_p ON s.serviceid = sl_p.servicedownid and sl_p.soft=0 WHERE (s.serviceid / 100000000000000)=0 ORDER BY s.sortorder, sl.serviceupid, s.serviceid] [ERROR: for SELECT DISTINCT, ORDER BY expressions must appear in select list]
    * pg_fetch_array() expects parameter 1 to be resource, boolean given[/var/www/html/zabbix/include/db.inc.php:394]
    I had looking for the solution but no results.
    Any ideas?
    Thanks a lot
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Thanks for reporting this, It will be fixed asap.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • Aly
      ZABBIX developer
      • May 2007
      • 1126
      It fixed since 1.4.1 is out.
      Zabbix | ex GUI developer
      • jpilldev
        • Oct 2008
        Error fixed
        Hello.
        I changed the Query in the archive /var/www/html/zabbix/services.php
        * Error in query [SELECT distinct s.serviceid, sl.servicedownid,
        >sl_p.serviceupid as serviceupid, s.name caption, s.algorithm, t.triggerid,
        Changed s.name as caption
        Later, Appears another Error:
        SELECT distinct s.serviceid, sl.servicedownid, sl_p.serviceupid as
        serviceupid, s.name as caption, s.algorithm, t.triggerid, s.sortorder,
        sl.linkid FROM services s LEFT JOIN triggers t ON s.triggerid = t.triggerid
        ORDER BY s.sortorder, sl.serviceupid, s.serviceid;
        And change at the same file:
        ORDER BY s.sortorder, sl.serviceupid, s.serviceid; by
        ORDER BY s.sortorder, sl_p.serviceupid, s.serviceid;
        Then I got another error of the same type, I fixed it and IT services works Fine.
