Has the zabbix_sender the same posibilities as the agent?
  • Tristan
    • Feb 2008
    • 110
    I use within my zabbix environment a lot of userparameters and it works perfect. But one of my coworkers had ask me if it's possible to use zabbix_sender to send the information to the zabbix server within a script.
    I have tried a few options but no results.
    When i use my zabbix_agent i use the following userparameter:
    UserParameter=appparam[*], cat /tmp/test.txt
    this works perfect, but when i use the syntax in zabbix_sender it doen't work:
    zabbix_sender -o cat /tmp/test.txt
    It just sends the string "cat /tmp/test.txt" to zabbix.
    so when i use a subshell it even doens't work:
    zabbix -o $( cat /tmp/test.txt )
    My question is: is this possible? I can use variable's but i need a better solution.
  • Tenzer
    • Nov 2007
    • 316
    Using '... -o "`cat test.txt`"' works fine for me, even with line changes and apostrophes.
    Btw, if you use the "-vv" flag, it makes it a lot easier to debug, as the data it's trying to send is written by the zabbix_sender.
    • Tristan
      • Feb 2008
      • 110
      Does someone has an idea to do the samething in windows with the zabbix_sender?
      I can't get it to work.
      • Tristan
        • Feb 2008
        • 110
        zabbix sender
