Fatal error: Call to undefined function socket_create() in /var/apache2/htdocs/zabbix16/include/scripts.inc.php on line 68
<?php
function get_script_by_scriptid($scriptid){
$sql = 'SELECT * FROM scripts WHERE scriptid='.$scriptid;
$rows = false;
if($res = DBSelect($sql)){
$rows = DBfetch($res);
return $rows;
function add_script($name,$command,$usrgrpid,$groupid,$access){
$scriptid = get_dbid('scripts','scriptid');
$sql = 'INSERT INTO scripts (scriptid,name,command,usrgrpid,groupid,host_access) '.
" VALUES ($scriptid,".zbx_dbstr($name).','.zbx_dbstr($command).",$usrgrpid,$groupid,$access)";
$result = DBexecute($sql);
if($result){
$result = $scriptid;
return $result;
function delete_script($scriptid){
$sql = 'DELETE FROM scripts WHERE scriptid='.$scriptid;
return $result;
function update_script($scriptid,$name,$command,$usrgrpid,$groupid,$access){
$sql = 'UPDATE scripts SET '.
' name='.zbx_dbstr($name).
' ,command='.zbx_dbstr($command).
' ,usrgrpid='.$usrgrpid.
' ,groupid='.$groupid.
' ,host_access='.$access.
' WHERE scriptid='.$scriptid;
return $result;
function script_make_command($scriptid,$hostid){
$host_db = DBfetch(DBselect('SELECT dns,useip,ip FROM hosts WHERE hostid='.$hostid));
$script_db = DBfetch(DBselect('SELECT command FROM scripts WHERE scriptid='.$scriptid));
if($host_db && $script_db){
$command = $script_db['command'];
$command = str_replace("{HOST.DNS}", $host_db['dns'],$command);
$command = str_replace("{IPADDRESS}", $host_db['ip'],$command);
$command = ($host_db['useip']==0)?
str_replace("{HOST.CONN}", $host_db['dns'],$command):
str_replace("{HOST.CONN}", $host_db['ip'],$command);
else{
$command = FALSE;
return $command;
function execute_script($scriptid,$hostid){
$res = 1;
$command = script_make_command($scriptid,$hostid);
$nodeid = id2nodeid($hostid);
[COLOR="Red"]$socket = socket_create(AF_INET, SOCK_STREAM, SOL_TCP);[/COLOR]
if(!$socket){
$res = 0;
if($res){
global $ZBX_SERVER, $ZBX_SERVER_PORT;
$res = socket_connect($socket, $ZBX_SERVER, $ZBX_SERVER_PORT);
if($res){
$send = "Command\255$nodeid\255$hostid\255$command\n";
socket_write($socket,$send);
if($res){
$res = socket_read($socket,65535);
if($res){
list($flag,$msg)=split("\255",$res);
$message["flag"]=$flag;
$message["message"]=$msg;
else{
$message["flag"]=-1;
$message["message"] = S_CONNECT_TO_SERVER_ERROR.' ['.$ZBX_SERVER.':'.$ZBX_SERVER_PORT.'] ['.socket_strerror(socket_last_error()).']';
if($socket){
socket_close($socket);
return $message;
function get_accessible_scripts_by_hosts($hosts){
global $USER_DETAILS;
if(!is_array($hosts)){
$hosts = array('0' => hosts);
// Selecting usrgroups by user
$sql = 'SELECT ug.usrgrpid '.
' FROM users_groups ug '.
' WHERE ug.userid='.$USER_DETAILS['userid'];
$user_groups = DBfetch(DBselect($sql));
$user_groups[] = 0; // to ALL user groups
// Selecting groups by Hosts
$sql = 'SELECT hg.hostid,hg.groupid '.
' FROM hosts_groups hg '.
' WHERE '.DBcondition('hg.hostid',$hosts);
$hg_res = DBselect($sql);
while($hg_rows = DBfetch($hg_res)){
$hosts_groups[$hg_rows['groupid']][$hg_rows['hostid']] = $hg_rows['hostid'];
$hg_groups[$hg_rows['groupid']] = $hg_rows['groupid'];
$hg_groups[] = 0; // to ALL host groups
$hosts_read_only = get_accessible_hosts_by_user($USER_DETAILS,PERM_READ_ONLY);
$hosts_read_write = get_accessible_hosts_by_user($USER_DETAILS,PERM_READ_WRITE);
$hosts_read_only = array_intersect($hosts,$hosts_read_only);
$hosts_read_write = array_intersect($hosts,$hosts_read_write);
// initialize array
foreach($hosts as $id => $hostid){
$scripts_by_host[$hostid] = array();
$sql = 'SELECT s.* '.
' FROM scripts s '.
' WHERE '.DBin_node('s.scriptid').
' AND '.DBcondition('s.groupid',$hg_groups).
' AND '.DBcondition('s.usrgrpid',$user_groups).
' ORDER BY scriptid ASC';
$res=DBselect($sql);
while($script = DBfetch($res)){
$add_to_hosts = array();
if(PERM_READ_WRITE == $script['host_access']){
if($script['groupid'] > 0)
$add_to_hosts = array_intersect($hosts_read_write, $hosts_groups[$script['groupid']]);
else
$add_to_hosts = $hosts_read_write;
else if(PERM_READ_ONLY == $script['host_access']){
$add_to_hosts = array_intersect($hosts_read_only, $hosts_groups[$script['groupid']]);
else
$add_to_hosts = $hosts_read_only;
foreach($add_to_hosts as $id => $hostid){
$scripts_by_host[$hostid][] = $script;
//SDI($scripts_by_host);
return $scripts_by_host;
