Using IPMI agent
I got caught out with IPMI today when I didn't realise the default number of pollers for IPMI is 0 even though --with-ipmi was built.
Although I haven't got the values working yet it is at least polling using Fedora 12, Zabbix 1.8.2 (revision 11096) and OpenIPMI.x86_64 2.0.16-4.fc12 and I do get error messages.
edit: Key power now works fine on a Dell SC1435 on the above server.
chassis.power.status didn't work though so i'll have to experiment with what I need to put into zabbix ipmi compared to what impitool will accept (ipmitool chassis power status -H <hostname> -U <user> -p 623 works for example).
This will be useful on ESX4i Dell's that don't do snmpget (i'm still working on traps) and the Dell servers that don't use full openmanage in the SC series.Last edited by craigwelsh; 26-03-2010, 17:29.Comment
IPMI is still not working on my zabbix installation (1.8.2).
Zabbix is compiled with openIPMI.
StartIPMIPollers=1 in zabbix_server.conf is set.
Querying with ipmitool is working fine.
But zabbix doesn't care...
Output of zabbix_server.log:
Message on hosts.php:Code:19332:20100404:192512.383 IPMI Host [HOSTNAME]: first network error, wait for 15 seconds 19325:20100404:192538.355 IPMI Host [HOSTNAME]: another network error, wait for 15 seconds 19325:20100404:192600.576 Disabling IPMI host [HOSTNAME]
Code:Cannot connect to IPMI host. Error 0x16 Invalid argument
I cannot get IPMI to work in my installation as well. I have a server -> proxy -> agent configuration, and have enable IPMI with openipmi on both server and prxy, set IPMIPoller to 1 in both server and proxy and enabled IPMI on one host via the web interface. But the IPMI icon is still disabled and there's no trace of IPMI polling going on. No errors, no warnings, nothing. What should I check?Comment
Hello to all , I've ipmi problem with our sunfire x4500 ilom version raging from 2.0.2.10 to 3.0.6.15.
I've recently upgraded to zabbix 1.8.2 , tried with openipmi 2.0.14 before and
openipmi 2.0.16 now, the zabbix platform running debian lenny x86.
On all host configured for ipmi I get "Cannot connect to IPMI host. Error 0x2000011 Unknown error 33554449"
StartIPMIPollers=3 in zabbix_server.conf and I'see ipmi pollers start in server's log.
ipmitool sensor -H x.x.x.x -L user -U <user> -P <pass> -p 623
Give me the right value
ACPI | 0x1 | discrete | 0x0100| na | na | na
| na | na | na
MB/P0/PRSNT | 0x2 | discrete | 0x0200| na | na | na
| na | na | na
MB/P1/PRSNT | 0x2 | discrete | 0x0200| na | na | na
| na | na | na
MB/P0/TCCAT | 0x3b | discrete | 0x3b00| na | na | na
| na | na | na
MB/P1/TCCAT | 0x39 | discrete | 0x3900| na | na | na
| na | na | na
MB/T_AMB0 | 50.000 | degrees C | ok | na | na | na
| 79.000 | 81.000 | na
MB/T_AMB1 | 48.000 | degrees C | ok | na | na | na
MB/T_AMB2 | 47.000 | degrees C | ok | na | na | na
| 90.000 | 95.000 | na
Any Ideas ???Comment
If U need traffic dump or other info I can post more , nobody as idea how to solve it ???
PLSSSS
and which sensor exactly are you trying to grab ?
remember that discrete sensors are not supportedComment
I try to grab temperature sensors
MB/T_AMB0 | 50.000 | degrees C | ok | na | na | na | 79.000 | 81.000 | na
voltage sensors
MB/V_+1V5 | 1.490 | Volts | ok | 1.193 | 1.271 | na | na | 1.716 | 1.794
and fan ones
PS1/F0/TACH | 8704.000 | RPM | ok | na | na | na
| na | na | na
I investigate more with ipmi protocols and auth
ipmitool sensor -I lanplus -H host-ipmi -A md5 -L user -U ipmiuser -P xxxx -p 623
ipmitool sensor -I lan -H host-ipmi -A md5 -L user -U ipmiuser -P xxxx -p 623
and in any case from command line I can get the right value .
In the log file of zabbix's server I read
2245:20100531:104408.652 IPMI Host [host-ipmi]: first network error, wait for 15 seconds
2228:20100531:104434.179 IPMI Host [host-ipmi]: another network error, wait for 15 seconds
2228:20100531:104451.378 Disabling IPMI host [host-ipmi]
TksComment
have you set auth to md5 in zabbix configuration ?
did you recompile zabbix server after upgrading openipmi library ?Comment
IPMI Errors
I'm getting very similar problems.
The remote hardware I'm trying to monitor is from HP. Its ILOM has the latest firmware.
On the Zabbix Server, I am using Ubuntu 10.4 LTS with Zabbix 1.8.1 & libopenipmi 2.0.16. I have 3 IPMI pollers running.
ipmitool (lanplus) works great, and gives me results like this:
Temp 1 | 27.000 | degrees C | ok |
I am trying to monitor "Temp 1" in Zabbix, but I get a red IPMI icon with this error:
Error 0x2000001 Unknown error 33554433
Sometimes it changes to this error:
Error 0x2000004 Unknown error 33554436
What do these errors mean?
Thanks.Comment
