Errors on Audit screen - Zabbix 1.6
  • MrKen
    • Oct 2008
    • 652
    Possible bug.
    When I enable or disable a host, on the Administration -> Audit page in the Action column it says 'Updated'. That's ok.
    But, when I enable or disable an item, the Action column says 'Deleted'. Fortunately it is not deleted, but it should read 'Updated'.
  • Aly
    ZABBIX developer
    • May 2007
    • 1126
    Thank you. Registered as ZBX-557 in zabbix bugtrack system.
    Zabbix | ex GUI developer
