Problems with Graphs in 1.6
  • Luie
    • Oct 2008
    Hello...
    Since i updated my zabbix to 1.6 i got some problems with the Graphs/Screens/Maps.
    Here a Screenshot from the Screen´s. All works fine.
    But if i click on a screen to zoom or select it, the graph will not shown probably.
    Someone known this problem?
    Regards, Luie
  • Luie
    • Oct 2008
    Hello again,
    in the last day´s i had some "free time" that i used to discover my problems and now i got more information about this.
    1. Maps
    The problem with the maps are only some broken links. I don´t know why they couldn´t not sown probably but after i delete all links in the maps and i create a new object on it, all works fine.
    2. Graphs
    The problem with my graphs are really confusing. As is tested it today no one, from my old graphs, will shown. So i play around with it and the confusing, in the configuration/graphs menu i see all graphs. Only in the overview zabbix couldn´t load the picture. If i edit the graphs and change the graph type (all are normal or stacked) to pie or explode, the pictures are viewable in the overview.
    Additionally if i set the "height" to 96 and the graph type is normal or stacked then i can also see the graph in monitoring. But if the "height" is greater than 96 i only see this error picture.
    Somebody any idea?
    Regards,Luie
    PS: Sorry for my english
