[zabbix-1.6] front-end disable triggers bug
  • zabbix_es
    • Apr 2007
    • 153
    Hello:
    In zabbix front-end 1.6, when you select triggers to disable checking checkboxes and pushing bottom button this command is ignored.
    Disabling triggers through left links works fine.
    I test this issue in Windows 2000 Proffesional with IExplorer 6.0.2800.1106.
    Best regards!
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    I am pretty sure it is already fixed in pre 1.6.1.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
