Hello:
1. In zabbix front-end Configuration->Graphs->Items links "Up" and "Down" don't work.
2. When editing a Graph, there isn't any help about "Percentile Line (*)" (well, there isn't any information about Graphs in manual) and, furthermore, if you check this checkboxes and save them when you re-edit the graph checkboxes are unchecked (but I think that graph shows percentile lines and you can't disable them).
3. I think also that stacked graphs don't work properly.
4. There is also an strange issue related with graphs asocciated to templates that creates serveral graphs with the same name in each item of template when it should be only one per item.
I recomend to review all related with zabbix graphs and fill in Graph chapter of Zabbix User's Manual.
