Zabbix server dies with LIBSQLORA8-30002 Error
  • luissma
    • Jul 2008
    • 16
    5399:20081021:142645 End get_values()
    5399:20081021:142645 Poller spent 0.036128 seconds while updating 0 values. Sleeping for 5 seconds
    5381:20081021:142645 In get_values()
    5381:20081021:142645 Query [select i.itemid,i.key_,h.host,h.port,i.delay,i.descriptio n,i.nextcheck,i.type,i.snmp_community,i.snmp_oid,h .useip,h.ip,i.history,i.lastvalue,i.prevvalue,i.ho stid,h.status,i.value_type,h.errors_from,i.snmp_po rt,i.delta,i.prevorgvalue,i.lastclock,i.units,i.mu ltiplier,i.snmpv3_securityname,i.snmpv3_securityle vel,i.snmpv3_authpassphrase,i.snmpv3_privpassphras e,i.formula,h.available,i.status,i.trapper_hosts,i .logtimefmt,i.valuemapid,i.delay_flex,h.dns,i.para ms,i.trends,h.useipmi,h.ipmi_port,h.ipmi_authtype, h.ipmi_privilege,h.ipmi_username,h.ipmi_password,i .ipmi_sensor from hosts h, items i where i.nextcheck<=1224592010 and i.status in (0,3) and i.type not in (2,7,9,12) and h.status=0 and h.disable_until<=1224592005 and h.errors_from=0 and h.hostid=i.hostid and (h.proxy_hostid=0 or i.type in (5)) and mod(i.itemid,5)=2 and i.key_ not in ('status','icmpping','icmppingsec','zabbix[log]') and h.hostid between 000000000000000 and 099999999999999 order by i.nextcheck]
    5381:20081021:142645 In int_in_list(list:,value:10053)
    5381:20081021:142645 End int_in_list(ret:FAIL)
    5381:20081021:142645 In get_value(key:sensor[temp3])
    5381:20081021:142645 In get_value_agent(host:XXXXXXXXXX,addr:XX.XX.XXX.XX, key:sensor[temp3])
    5381:20081021:142645 Sending [sensor[temp3]
    5381:20081021:142645 End get_value_agent(result:ZBX_NOTSUPPORTED)
    5381:20081021:142645 End get_value()
    5381:20081021:142645 In DBupdate_item_status_to_notsupported()
    5381:20081021:142645 Query [update items set status=3,lastclock=1224592005,nextcheck=1224592605 ,error='Not supported by ZABBIX agent' where itemid=22602]
    5381:20081021:142645 Query [select t.triggerid,t.expression,t.description,t.url,t.com ments,t.status,t.value,t.priority from triggers t,functions f,items i where t.triggerid=f.triggerid and f.itemid=i.itemid and t.status in (0) and t.value not in (2) and i.itemid=22602]
    5381:20081021:142645 Query::select t.triggerid,t.expression,t.description,t.url,t.com ments,t.status,t.value,t.priority from triggers t,functions f,items i where t.triggerid=f.triggerid and f.itemid=i.itemid and t.status in (0) and t.value not in (2) and i.itemid=22602
    5381:20081021:142645 Query failed:SLQORALIB *** FATAL *** : allocation of statement failedLIBSQLORA8-30002: Memory allocation error.
    (sqlora line: 5249)
    5372:20081021:142645 One child process died. Exiting ...
    5382:20081021:142645 Got signal. Exiting ...
    5390:20081021:142645 Got signal. Exiting ...
    5379:20081021:142645 Got signal. Exiting ...
    5391:20081021:142645 Got signal. Exiting ...
    5392:20081021:142645 Got signal. Exiting ...
    5393:20081021:142645 Got signal. Exiting ...
    5394:20081021:142645 Got signal. Exiting ...
    5399:20081021:142645 Got signal. Exiting ...
    5402:20081021:142645 Got signal. Exiting ...
    5380:20081021:142645 Got signal. Exiting ...
    5383:20081021:142645 Got signal. Exiting ...
    5387:20081021:142645 Got signal. Exiting ...
    5384:20081021:142645 Got signal. Exiting ...
    5406:20081021:142645 Got signal. Exiting ...
    5405:20081021:142645 Got signal. Exiting ...
    5397:20081021:142645 Got signal. Exiting ...
    5398:20081021:142645 Got signal. Exiting ...
    5372:20081021:142647 ZABBIX Server stopped. ZABBIX 1.6.
