How to install upgrades from svn(dbpatches)?
  • gdorm
    • Oct 2008
    How to patch the database with the patches from svn? Thanks.
  • xs-
    • Dec 2007
    • 393
    If you are using this for a production environment: i advise against this.
    Database upgrades are only supported from stable to stable release. Once you patch your database with a development release patch, you will have to upgrade your database manually from that point on (which requires in-depth knowledge of the current state of the zabbix db and a good portion of sql knowledge).
    • gdorm
      • Oct 2008
      I get you point.Thanks
