simplecheck with http, cannot be used to check other than port 80
  • jaraju
    • Jun 2005
    • 9
    Hi guys!
    I'm experimenting with zabbix and i came across this problem. I'm using Simple Check with key: http to monitor my Windows 2000 server running web service. Using default port (port 80), everything works fine.
    But when i changed my web service port to 8080, the zabbix server couldn't monitor my Windows machine web service any more. Is there anyway to change port? I dont see any options for that in here: http://www.zabbix.com/manual_config_items.php
    Please let me know.
    Thanks in advance!
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Try key "http,8080".
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • jaraju
      • Jun 2005
      • 9
      Wow that was a fast reply Alexei.
      I edited the key and typed: http,8080 as u mentioned and it worked!
      Thanks!
