Userparameter not working
  • vincefp
    • Aug 2008
    I try to setup userparameter but it don't work. I've tried :
    zabbix_agentd -t antivirus ------> result: [1|t] When i'm using v 1.4.6
    zabbix_agentd -t antivirus ------> result: [NOT_SUPPORTED|m] When i'm using v 1.5.3
    But the value is not in the zabbix frontend. I don't understand what is the problem.
    This is my zabbix setup:
    ZABBIXSERVER------ZABBIXPROXY-----ZABBIXAGENT(WIN32)
    Thanks.
    PHP Code:
    # List of comma delimited IP addresses (or hostnames) of ZABBIX servers.
    # No spaces allowed. First entry is used for sending active checks.
    # Note that hostnames must resolve hostname->IP address and
    # IP address->hostname.
    Server=192.168.1.252
    # Server port for sending active checks
    #ServerPort=10051
    # Unique hostname. Required for active checks.
    Hostname=SERVER2
    # Listen port. Default is 10050
    #ListenPort=10050
    # IP address to bind agent
    # If missing, bind to all available IPs
    #ListenIP=127.0.0.1
    # Number of pre-forked instances of zabbix_agentd.
    # Default value is 5
    # This parameter must be between 1 and 16
    StartAgents=5
    # How often refresh list of active checks. 2 minutes by default.
    #RefreshActiveChecks=120
    # Disable active checks. The agent will work in passive mode listening server.
    DisableActive=0
    # Enable remote commands for ZABBIX agent. By default remote commands disabled.
    #EnableRemoteCommands=1
    # Specifies debug level
    # 0 - debug is not created
    # 1 - critical information
    # 2 - error information
    # 3 - warnings (default)
    # 4 - for debugging (produces lots of information)
    DebugLevel=4
    # Name of PID file
    PidFile=C:\tmp\zabbix_agentd.pid
    # Name of log file.
    # If not set, syslog will be used
    LogFile=C:\tmp\zabbix_agentd.log
    # Maximum size of log file in MB. Set to 0 to disable automatic log rotation.
    #LogFileSize=1
    # Spend no more than Timeout seconds on processing
    # Must be between 1 and 30
    Timeout=20
    UserParameter
    =antivirus,cscript.exe //nologo avget.vbs
