Fatal error: Allowed memory size of
  • cjwallace
    • Sep 2008
    • 126
    Guys.
    Every now and again i get the following
    Fatal error: Allowed memory size of 16777216 bytes exhausted (tried to allocate 786615 bytes) in /home/zabbix/public_html/include/classes/ctag.inc.php on line 77
    Any ideas?
  • vrtareg
    • May 2006
    • 293
    Hi
    You need to change "Resource Limits" section in your php.ini file and increase memory_limit value.
    Regards
    Areg
    • cjwallace
      • Sep 2008
      • 126
      Thanks mate.
      I have done that and made it 128MB do you think this will be ok?
      Craig
      • vrtareg
        • May 2006
        • 293
        Hi
        You need to find this value experimentaly.
        For example if you create a screen with many graphs you can set it to 256mb.
        Regards
        Areg
        • cjwallace
          • Sep 2008
          • 126
          Ahhh ok, Well i will keep an eye on it and adjust as needed. The server has 5GB of RAM installed so should have enough kicking around.
          Thanks again for passing the knowledge on.
          Craig
          • vrtareg
            • May 2006
            • 293
            Hi
            Yes you can.
            It depends on amount of physical memory size.
            You can find this value experimentaly.
            Regards
            Areg
            • vrtareg
              • May 2006
              • 293
              Welcome
              Areg
