Zabbix agentd on windows 2008 x64 problem
  • DesMnatez
    • Oct 2008
    Has anyone achieved to run Zabbix agentd on windows 2008 x64 (win 2k8 is not in the list of supported OS)?
    Zabbix agentd is running but the problem is that I defined User Parameter to run a script, to monitor windows service. On localhost script is running and returning value (1 or 0) but the catch is that zabbix server cannot run the cript and it's not receiving the value. What could be the problem?
  • bbrendon
    • Sep 2005
    • 873
    I have a 1.4.6 agent running on 2008 x64 with no problems.
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • DesMnatez
      • Oct 2008
      bbrendon thx for replay....
      Don't know how but now it's working
      • swaterhouse
        • Apr 2006
        • 268
        sounds like a permissions problem. The Zabbix Agent service by default runs as under the local system account and may not have permission to run the script.
        Did you know you can check the service state without custom scripts?
