Zabbix 1.6.1: which SVN Tag release corresponds?
  • sean
    • Mar 2008
    • 28
    It would be nice in the "Changelog" if the SVN version tag was appended to the description line for new releases (i.e. revision 6255 now, but two mods from v1.6.2 are already in there).
    Since I have the SVN pulled already it seems natural to install/upgrade Zabbix from svn, but with the correct tag for 1.6.1.
    Once I've done this I can use svn diff to follow evolution of fixes in the stable branch.
    Does that make sense? Or is strick use of tarballls recommened for production sites?
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Well, obviously '1.6.1. is the tag name for version 1.6.1.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • sean
      • Mar 2008
      • 28
      Er, I meant the SVN number revision. But yes this could be looked up from the tag. I just though it would have been interesting to write the SVN version number in the CHANGLOG.
