New IP format in zabbix_agentd.conf ::ffff:192.168.2.100 ??
  • OneLoveAmaru
    • Jan 2008
    • 41
    Guys, upgraded from 1.4.6 to 1.6 (server and agent) on Debian Lenny and then i was getting some empty parameter errors. I looked in the logs and it was rejecting the DNS names and the IP's I had listed for the zabbix servers.
    Basically the fix was to put in the IP like this, "::ffff:192.168.2.100". Is this normal now for 1.6, since it supports IPv6? I tried searching the forum but couldn't find anything like this. If this is just Debian's fault, let me know and I can put in a bug report with them, thanks. If this is normal now, then I would want to know that too...
    Thanks!
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    It is normal if you have IPv6 support compiled in and your system uses IPv6.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • OneLoveAmaru
      • Jan 2008
      • 41
      Thanks. The maintainers must have compiled it with IPv6 support.
