md5.c:54:20: error: common.h
  • Rogoschin
    • Nov 2008
    Good Evening
    I've tried to install Zabbix 1.6 Server in my virtual Debian Server.
    After a view problems, installing a lot of dev's, i could start the installation.
    Now i got this error:
    Configuration:
    Detected OS: linux-gnu
    Install path: /usr/local
    Compilation arch: linux
    Compiler: gcc
    Compiler flags: -g -O2 -I/usr/include/mysql -DBIG_JOINS=1 -I. -I/usr/include -I/usr/include
    Enable server: yes
    With database: MySQL
    WEB Monitoring via: cURL
    Native Jabber: no
    SNMP: net-snmp
    IPMI: no
    Linker flags: -L/usr/lib -lldap -L/usr/lib/mysql -L/usr/lib -lcurl -L/usr/lib -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lkrb5support -lresolv -lidn -lssl -lcrypto -ldl -lssl -lcrypto -lz -L/usr/lib -lnetsnmp -lm -lwrap -lwrap -lcrypto -L/usr/lib -lnetsnmp -lm -lwrap -lwrap -lcrypto
    Libraries: -lm -lresolv -lmysqlclient -lcurl -lnetsnmp
    Enable proxy: no
    Enable agent: yes
    LDAP support: yes
    IPv6 support: no
    * Now run 'make install' *
    * Thank you for using ZABBIX! *
    * <http://www.zabbix.com> *
    debian:/home/rogoschin/Desktop/Zabbix/zabbix-1.6.1# make install
    Making install in src
    make[1]: Entering directory `/home/rogoschin/Desktop/Zabbix/zabbix-1.6.1/src'
    Making install in libs
    make[2]: Entering directory `/home/rogoschin/Desktop/Zabbix/zabbix-1.6.1/src/libs'
    Making install in zbxcrypto
    make[3]: Entering directory `/home/rogoschin/Desktop/Zabbix/zabbix-1.6.1/src/libs/zbxcrypto'
    gcc -DHAVE_CONFIG_H -I. -I../../../include -g -O2 -I/usr/include/mysql -DBIG_JOINS=1 -I. -I/usr/include -I/usr/include -MT md5.o -MD -MP -MF .deps/md5.Tpo -c -o md5.o md5.c
    md5.c:54:20: error: common.h: Datei oder Verzeichnis nicht gefunden
    md5.c: In function ‘md5_process’:
    md5.c:170: warning: incompatible implicit declaration of built-in function ‘memcpy’
    md5.c: In function ‘md5_append’:
    md5.c:344: warning: incompatible implicit declaration of built-in function ‘memcpy’
    md5.c:358: warning: incompatible implicit declaration of built-in function ‘memcpy’
    make[3]: *** [md5.o] Fehler 1
    make[3]: Leaving directory `/home/rogoschin/Desktop/Zabbix/zabbix-1.6.1/src/libs/zbxcrypto'
    make[2]: *** [install-recursive] Fehler 1
    make[2]: Leaving directory `/home/rogoschin/Desktop/Zabbix/zabbix-1.6.1/src/libs'
    make[1]: *** [install-recursive] Fehler 1
    make[1]: Leaving directory `/home/rogoschin/Desktop/Zabbix/zabbix-1.6.1/src'
    make: *** [install-recursive] Fehler 1
    Does someone know this problem?
    Thanks 4 help.
    Datei oder Verzeichnis nicht gefunden means File or Path not found.
  • Rogoschin
    • Nov 2008
    Does someone know witch failure i did?
    • Rogoschin
      • Nov 2008
      I've found the problem, the file was missing, i think cause download failure.....
      • Rogoschin
        • Nov 2008
        I've got another problem on freebsd
