CPU, mem and other simultaneous data graphing
  • ghislain
    • Jun 2005
    • 160
    hi,
    i have an issue with graphing of data that represent a constant sum. For exemple cpu time is
    idle+user+nice+system =100%
    But zabbix agent do not grab the value at the same moment so when i have a quick peak my graph goes to 250%.... because of a time shift between values. Do i missed an option somewhere to ask zabbix to sync all the cpu element ? I have the same issue with other metrics but cpu is the most used.
    Is the only solution to write a c script that use zabbix sender to report to the monitoring server ?
    Regards,
    Ghislain.
    Regards,
    Ghislain.
  • bbrendon
    • Sep 2005
    • 873
    Interesting. If what you say is true, then your best bet is to probably write your own user parameter.
    Unofficial Zabbix Expert
    Blog, Corporate Site
