hi,
i try to compile the new agent (1.6.1) on freebsd 4.x. I got this error, perhaps you can help me here:
I got this error:
make clean ; ./configure --enable-static --disable-server --enable-agent --disable-ipv6 --disable-proxy --without-jabber --without-net-snmp --without-ucd-snmp
Configuration:
Detected OS: freebsd4.7
Install path: /usr/local
Compilation arch: freebsd
Compiler: gcc
Compiler flags: -g -O2
Enable server: no
Enable proxy: no
Enable agent: yes
Linker flags: -static
Libraries: -lkvm -lm
LDAP support: no
IPv6 support: no
* Now run 'make install' *
* Thank you for using ZABBIX! *
* <http://www.zabbix.com> *
(aqadmin)> make
Making all in src
Making all in libs
Making all in zbxcrypto
Making all in zbxcommon
Making all in zbxlog
Making all in zbxnix
Making all in zbxconf
Making all in zbxsysinfo
Making all in common
Making all in simple
Making all in freebsd
source='proc.c' object='libspecsysinfo_a-proc.o' libtool=no DEPDIR=.deps depmode=gcc /usr/local/bin/bash ../../../../depcomp gcc -DHAVE_CONFIG_H -I. -I../../../../include -I../../../../src/zabbix_agent/ -g -O2 -c -o libspecsysinfo_a-proc.o `test -f 'proc.c' || echo './'`proc.c
In file included from ../../../../include/sysinc.h:77,
from ../../../../include/common.h:23,
from proc.c:20:
/usr/include/grp.h:58: warning: parameter names (without types) in function declaration
proc.c: In function `get_commandline':
proc.c:49: structure has no member named `ki_pid'
proc.c:67: structure has no member named `ki_comm'
proc.c: In function `PROC_MEMORY':
proc.c:106: `COMMLEN' undeclared (first use in this function)
proc.c:106: (Each undeclared identifier is reported only once
proc.c:106: for each function it appears in.)
proc.c:148: `KERN_PROC_PROC' undeclared (first use in this function)
proc.c:168: structure has no member named `ki_comm'
proc.c:179: structure has no member named `ki_tsize'
proc.c:180: structure has no member named `ki_dsize'
proc.c:181: structure has no member named `ki_ssize'
proc.c: In function `PROC_NUM':
proc.c:239: `COMMLEN' undeclared (first use in this function)
proc.c:279: `KERN_PROC_PROC' undeclared (first use in this function)
proc.c:301: structure has no member named `ki_comm'
proc.c:307: structure has no member named `ki_stat'
proc.c:311: structure has no member named `ki_stat'
proc.c:315: structure has no member named `ki_stat'
*** Error code 1
Stop in /usr/local/.aqadmin/home/aqadmin/zabbix-1.6.1/src/libs/zbxsysinfo/freebsd.
*** Error code 1
Stop in /usr/local/.aqadmin/home/aqadmin/zabbix-1.6.1/src/libs/zbxsysinfo.
*** Error code 1
Stop in /usr/local/.aqadmin/home/aqadmin/zabbix-1.6.1/src/libs.
*** Error code 1
Stop in /usr/local/.aqadmin/home/aqadmin/zabbix-1.6.1/src.
*** Error code 1
Stop in /usr/local/.aqadmin/home/aqadmin/zabbix-1.6.1.
This is on jail based virtual hosting, agent from 1.4.x work fine here . Any idea of the problem ?
regards,
Ghislain.
I got this error:
Configuration:
Compiler: gcc
Enable server: no
Enable proxy: no
Enable agent: yes
LDAP support: no
IPv6 support: no
(aqadmin)> make
Making all in src
Making all in libs
from proc.c:20:
*** Error code 1
*** Error code 1
*** Error code 1
*** Error code 1
*** Error code 1
regards,
Ghislain.
