zabbix-1.6 on RHEL 3 error while compiling
  • mario.almeida
    • Nov 2008
    • 44
    Hi All,
    trying to compile zabbix-1.6 as proxy on rhel3 update 6 but got the bellow errors
    ./configure --enable-proxy --with-mysql --enable-agent
    make
    +++++++++++errors+++++++++++++++
    make[3]: Leaving directory `/root/zabbix-1.6/src/libs/zbxjson'
    Making all in zbxdb
    make[3]: Entering directory `/root/zabbix-1.6/src/libs/zbxdb'
    if gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -g -O2 -I'/usr/include/mysql' -MT db.o -MD -MP -MF ".deps/db.Tpo" -c -o db.o db.c; \
    then mv -f ".deps/db.Tpo" ".deps/db.Po"; else rm -f ".deps/db.Tpo"; exit 1; fi
    db.c: In function `zbx_db_connect':
    db.c:87: `CLIENT_MULTI_STATEMENTS' undeclared (first use in this function)
    db.c:87: (Each undeclared identifier is reported only once
    db.c:87: for each function it appears in.)
    make[3]: *** [db.o] Error 1
    make[3]: Leaving directory `/root/zabbix-1.6/src/libs/zbxdb'
    make[2]: *** [all-recursive] Error 1
    make[2]: Leaving directory `/root/zabbix-1.6/src/libs'
    make[1]: *** [all-recursive] Error 1
    make[1]: Leaving directory `/root/zabbix-1.6/src'
    make: *** [all-recursive] Error 1
    if i compile with
    ./configure --with-mysql --enable-agent
    and then run make i get no errors
    help very urgent
    //Remy
  • mario.almeida
    • Nov 2008
    • 44
    Upgraded mysql to 5 and issue solved
    Originally posted by mario.almeida
    Hi All,
    make
    Making all in zbxdb
    if i compile with
    help very urgent
    //Remy
