Not found NET-SNMP library
  • ahui
    • Aug 2008
    • 14
    hi,
    i have error in configuration of Zabbix 1.6.1. I'm on Suse 10.0 and use net-snmp 5.3. I have problem on SNMP.See the problem:
    checking for net-snmp-config... /usr/bin/net-snmp-config
    checking for main in -lcrypto ... (cached) yes
    checking for main in -lm ... (cached) yes
    checking for main in -lwrap ... yes
    checking for main in -lnetsnmp ... no
    configure: error: Not found NET-SNMP library
    I have tried other thread but i can't resolve the problem.
    my parameters are:
    ./configure --with-mysql --with-net-snmp --with-libcurl --enable-server --enable-static --prefix=/zabbix
    Someone can help me ??
    Thank you
    Ahui SIKA
  • wibbit
    • Oct 2008
    • 13
    Do you have the net-snmp development libraries present?
    • ahui
      • Aug 2008
      • 14
      Thank you for your reply,
      net-snmp-devel is install
      see the response of: rpm -qa | grep snmp:
      net-snmp-devel-5.3.0.1-25.2
      net-snmp-5.3.0.1-25.2
      php5-snmp-5.1.2-29.5
      thank you
      Ahui SIKA
      • ahui
        • Aug 2008
        • 14
        hi
        No body to help me ?
        Thank for help
        Ahui SIKA
        • wibbit
          • Oct 2008
          • 13
          Some people don't monitor these sites hour in hour out, so if you don't get a reply instantly, getting upset isn't going to help.
          Their should be a configure log file generated by the configuration script, which should give you a bit more information.
          Review the log file, and find the line where it checks for snmp, what does it say?
          • akatsuki
            • Nov 2008
            • 10
            Execute command;
            $ net-snmp-config --libs
            You will see paths net-snmp library installed.
            And then check the symbolic link 'libnetsnmp.so' existance in those pathes directories.
            If libnetsnmp.so does not exist, make a symbolic link to physical file, named like libnetsnmp.so.10.X.X, in the directory.
            • bondbig
              • Jul 2008
              • 68
              i had the same problem
              I had the same problem.
              'libnetsnmp.so' exists in
              ns1n:/usr/src/zabbix-1.6.1 # net-snmp-config --libs
              -L[B]/usr/lib[/B] -lnetsnmp -lcrypto -lm -L[B]/usr/lib[/B] -lwrap
              ns1n:/usr/lib # ls -l | grep libnetsnmp.so
              lrwxrwxrwx   1 root root      20 Dec 11 15:00 libnetsnmp.so -> libnetsnmp.so.10.0.1
              lrwxrwxrwx   1 root root      20 Dec 11 15:00 libnetsnmp.so.10 -> libnetsnmp.so.10.0.1
              -rwxr-xr-x   1 root root  622080 Apr 24  2008 libnetsnmp.so.10.0.1
              Part of config.log:
              configure:10604: checking for net-snmp-config
              configure:10622: found /usr/bin/net-snmp-config
              configure:10635: result: /usr/bin/net-snmp-config
              configure:10758: checking for main in -lnetsnmp
              configure:10787: gcc -o conftest -g -O2   -I/usr/include/mysql -march=i586 -mtune=i686 -fmessage-length=0 -D_FORTIFY_SOURCE=2 -g -DPIC -fPIC -DUNDEF_HAVE_INITGROUPS -fno-strict-aliasing     -I/usr/include/rpm -I. -I/usr/include    -L/usr/lib -lnetsnmp -lcrypto -lm -L/usr/lib -lwrap -lcrypto conftest.c -lnetsnmp   -lm -lresolv   >&5
              /usr/lib/gcc/i586-suse-linux/4.1.2/../../../../i586-suse-linux/bin/ld: cannot find -lwrap
              collect2: ld returned 1 exit status
              configure:10793: $? = 1
              But then i installed tcpd-devel (tcp wrapper library) and problem was solved.
              • vjunior1981
                • Nov 2009
                • 10
                Man... you're simple the best... thanks!
                • Oper.kh
                  • Jan 2010
                  For Debian:
                  apt-get install libsnmp-dev
                  • efrain02
                    Banned
                    • Apr 2011
                    • 81
                    I have installed the apt-get install libsnmp-dev but i still can't make it work. I try to make snap-walk but apparently i don't have that command. Please somebody help me.
                    Thanks in advance!
