Once a week, zabbix is crashing with the problem :
Query::insert into trends (clock,itemid,num,value_min,value_avg,value_max) values (1228338000,19223,1,1.000000,1.000000,1.000000)
23501:20081203:220023 Query failed:PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "trends_pkey"
23501:20081203:220023 Query::update items set nextcheck=1228338143,prevvalue=lastvalue,lastvalue ='1.000000',lastclock=1228338023 where itemid=19223
23501:20081203:220023 Query failed:PGRES_FATAL_ERROR:ERROR: current transaction is aborted, commands ignored until end of transaction block
23501:20081203:220023 Query::select distinct function,parameter,itemid,lastvalue from functions where itemid=19223
23474:20081203:220024 One child process died. Exiting ...
I've tried to cleans trends for itemid 19223, but the problem is still here...
I'm using postgresql 8.3.5 and zabbix 1.6.1
Another question why zabbix is crashing when there's an SQL error, I think the excpetion should be try/catched and an alert mail should be sent! because now, i've a monitoring program that monitor zabbix (a monitor for the monitor)!!!
