Serious code issues
  • geno
    • Nov 2008
    • 29
    Serious code issues
    Hi guys, I've tried support.zabbix.com and looked around for a more appropriate place to post this..
    After being through the manual more than once, fiddling around with zabbix configuration for a few weeks, trolling/search/reading the forums all to no avail, I've decided to dig into the src code and the db structure to try and get answers.
    I though I'd start with a src code compare between 1.6 and 1.6.1, and within a minute or so discovered the following (I've just copied two lines to illustrate the problem, this happened on almost all of the lines in this file, did someone loose their 'T' key?):
    1.6:dbschema.c:1947
    httpstepitemid bigint DEFAULT '0' NOT NULL,\
    httpstepid bigint DEFAULT '0' NOT NULL,\
    1.6.1:dbschema.c:1947
    h ps epi emid bigin DEFAULT '0' NOT NULL,\
    h ps epid bigin DEFAULT '0' NOT NULL,\
    Not sure how this happens guys, but it would definately cause problems. Do you do code diffs before public release? QA cycle?
    Now I'm really interested to see what the rest of the source looks like! Will post more later...
    Anyways, I'm thinking of getting involved in the DEV side of Zabbix, really like this project, what do I do to join?
  • troffasky
    • Jul 2008
    • 640
    Submit a patch? ;-)
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Please do more research first. The "Serious code issues" as you call it affects auto-creation of Sqlite database in Proxy based environment. This is already fixed, no need to create a patch.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • varrocs
        • May 2008
        I came across with this problem at auto-creating the Sqlite database. The 't' letters are substituted with a space. I checked the code of release 1.6.1 , but I've seen no sign of fixing this.
        Maybe I ran over the it somewhere. In which version is that, or where can I find the patch.
        Thaks,
        Csaba
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          The fix is not in 1.6.1 (well, it fixes this version), it will be out along with 1.6.2.
          Alexei Vladishev
          My Twitter
