Zabbix 1.6.1 - Not Syncing Between Nodes
  • abhi238
    • Aug 2007
    • 15
    I am trying to configure Master/Child Nodes setup but the syncing of nodes does not work.
    I noticed a thread with the same issue for 1.4.1 and they provided a fix but same fix cannot be tried for the 1.6.1 "nodewatcher/nodesender.c" as code seems to have changed. The same problem is noticed with zabbix 1.6.1 and not fixed.
    From the Master node Web Interface, if I select child node then I get error "Unable to select configuration" and vice-versa.
    From both the nodes with verbose=4, I see only starting sync messages but not doing actual sync:
    Below is the snippet of the zabbix_server.log file:
    1459:20081217:170347 Starting sync with nodes
    1459:20081217:170357 Starting sync with nodes
    1459:20081217:170407 Starting sync with nodes
    1459:20081217:170417 Starting sync with nodes
    1459:20081217:170427 Starting sync with nodes
    1459:20081217:170437 Starting sync with nodes
    1459:20081217:170447 Starting sync with nodes
    1459:20081217:170457 Starting sync with nodes
    1459:20081217:170507 Starting sync with nodes
    Kindly advice,
    Zabbix 1.6.1:
    Monitored Hosts/Items : 1700/20000
    Monitored Host/Items (Proxy) : 1045/13500
  • abhi238
    • Aug 2007
    • 15
    ok. I resolved this.
    The issue was with the mismatch of the masterid's of both master/child on the mysql DB on both master/child.
    • wakko
      • Dec 2008
      • 19
      Can you give a more detailed description of the solution? I'm having the same issue.
      • abhi238
        • Aug 2007
        • 15
        You need to see that the masterid in the nodes table on both master/child is same.
        I.E.: Run the below query on both the master/child nodes DB and verify if they are the same. They should be the same or else you will face the sync issue.
        mysql> select nodeid,name,masterid from nodes;
        | nodeid | name | masterid |
        | 1 | Master node | 0 |
        | 2 | Child Node | 1 |
        2 rows in set (0.00 sec)
        Hope this helps,
        Regards,
        Abhijit
        • wakko
          • Dec 2008
          • 19
          Thank you for the additional details.
          It looks like I have the same problem, but updating the nodes table to align the values doesn't seem to have helped. Were there any other steps you took?
          • abhi238
            • Aug 2007
            • 15
            Ok. This is how I setup the Master/Child:
            Master IP/Port: <IP>/10051
            child IP/Port: <IP>/10051
            On Master:
            1. Set NodeID=1 in the /etc/zabbix/zabbix_server.conf.
            2. Exec: zabbix_server -n 1 -c /etc/zabbix/zabbix_server.conf
            3. From Master Web Interface:
            a) Added/Updated the Master Node details from Administration->Nodes Tab
            b) Added/Updated the Child Node details
            On Child:
            1. Set NodeID=2 in the /etc/zabbix/zabbix_server.conf.
            2. Exec: zabbix_server -n 2 -c /etc/zabbix/zabbix_server.conf
            a) Updated the Master Node details from Administration->Nodes Tab
            Verified the masterid column values are identical in the NODES tables for both master/child's database.
            Start Zabbix server daemons on both and verify /tmp/zabbix_server.log
            You should see something similar in the Master logs if sync works:
            25489:20081218:211841 NODE 1: Received data from slave node 2 for node 2 datalen 8
            25485:20081218:211849 NODE 1: Received history from node 2 for node 2 datalen 126
            25487:20081218:211849 NODE 1: Received history_uint from node 2 for node 2 datalen 342
            25487:20081218:211856 NODE 1: Received history_uint from node 2 for node 2 datalen 209
            25493:20081218:211857 NODE 1: Received history_str from node 2 for node 2 datalen 102
            25493:20081218:211906 NODE 1: Received history from node 2 for node 2 datalen 126
            25491:20081218:211907 NODE 1: Received history_uint from node 2 for node 2 datalen 250
            25491:20081218:211917 NODE 1: Received history from node 2 for node 2 datalen 58
            25489:20081218:211917 NODE 1: Received history_uint from node 2 for node 2 datalen 255
            25485:20081218:211918 NODE 1: Received history_str from node 2 for node 2 datalen 94
            25485:20081218:211926 NODE 1: Received history from node 2 for node 2 datalen 175
            25487:20081218:211927 NODE 1: Received history_uint from node 2 for node 2 datalen 154
            25493:20081218:211927 NODE 1: Received history_str from node 2 for node 2 datalen 156
            25489:20081218:212050 NODE 1: Received data from slave node 2 for node 2 datalen 8
            25491:20081218:212258 NODE 1: Received data from slave node 2 for node 2 datalen 8
            25493:20081218:212505 NODE 1: Received data from slave node 2 for node 2 datalen 8
            25487:20081218:212712 NODE 1: Received data from slave node 2 for node 2 datalen 8
            On the Child Node /tmp/zabbix_server.log you will notice similar messages as seen below:
            1530:20081223:101054 NODE 2: Sending configuration changes to master node 1 for node 2 datalen 9
            1530:20081223:101059 NODE 2: Received data from master node 1 for node 2 datalen 151
            1530:20081223:101102 NODE 2: Sending history_sync of node 2 to node 1 datalen 413
            1530:20081223:101103 NODE 2: Sending history_uint_sync of node 2 to node 1 datalen 1271
            1530:20081223:101104/ NODE 2: Sending history_str_sync of node 2 to node 1 datalen 296
            1530:20081223:101107 NODE 2: Sending trends of node 2 to node 1 datalen 89
            1530:20081223:101109 NODE 2: Sending trends_uint of node 2 to node 1 datalen 64
            If this does not help, let me know more details of your setup and output of below queries on both master/child:
            1. select nodeid,name,masterid from nodes;
            2. select userid from users;
            Happy Holidays!!
            • wakko
              • Dec 2008
              • 19
              Weird. I'd swear those are the steps I followed earlier today.
              However, I redid them again and now it works.
              Now to sort out the ACLs on the switches to allow the traffic through.
              Thanks for your help!
