Graphs apply for template
  • overnet
    • Mar 2008
    • 33
    I wanted to create a graph (e.g network utilization) and apply that graph to a template, but when I click on Item (Conf.-->Graph) I can only select a host not a template, is there another way to apply a graph to a template?
    What I'm trying to achieve? Is being able to see graphs for all hosts in a template.
    Thank you,
  • MrKen
    • Oct 2008
    • 652
    Yes, exactly as you described!
    Configuration --> Graphs [You might need to choose 'Group' all or 'Group' Template] They should be there .
    If you go Monitoring --> Graphs , you will not see templates!
    Cheers,
    MrKen
    • overnet
      • Mar 2008
      • 33
      Thank you MrKen.
      I've attached screenshots for the options I have when I try to add a graph.
      Graph1: Appears after I click on Add (a graph for the items)
      Graph2: When I click on Select.
      As you can see from graph2: I can select a node, a group and a host. Under host I can't see any template only hosts, so using this menu I can't create a graph for a template ONLY for a single host.
      Is there anything am missing here?
      Thank you
      • MrKen
        • Oct 2008
        • 652
        Well, yes, you missed Graph 2.
        But anyway, I think you need to go back one step. Before you click 'Create Graph', you need to select the Group and/or Host in the dropdown boxes.
        You need to select your Host 'Template' before the image that you have shown above.
        MrKen
        • troffasky
          • Jul 2008
          • 640
          The way I read that, what you want is one place where you can simultaneously see all the graphs for the children of a given template. Unfortunately I don't think this is possible without creating a 'Screen'. When I go to the Graphs view, it's not possible to view more than one host or graph a time.
          An 'Add this Graph to Screen...' button or checkbox would be useful.
