Zabbix proxy with active agents?
  • bbrendon
    • Sep 2005
    • 873
    It seems zabbix doesn't support active agents with proxy servers. Is this correct? If so, when will it be supported?
    If I'm incorrect, what am I doing wrong?
    In the proxy server log:
     10047:20081223:190005 Send list of active checks to [172.x.x.36] failed: host [hostWithActiveAgent] not found
    Unofficial Zabbix Expert
    Blog, Corporate Site
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Proxy does support items of all types including active items, SNMP, external (simple) checks, everything. Check if your host is defined and configured to be monitored by the proxy.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • bbrendon
      • Sep 2005
      • 873
      Ah ha!
      Found the problem. I needed to restart the proxy once I added the agent to the proxy in the GUI.
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        You don't have to restart anything. ZABBIX Proxy automatically refreshes configuration every one hour by default, the period can be changed.
        Alexei Vladishev
        My Twitter
        • bbrendon
          • Sep 2005
          • 873
          Hmmm. Can you make this dynamic? So if the proxy gets a new agent request then it goes and fetches its configuration?
          I would hate to set ConfigFrequency=60.
          Basically, I see the problem when you add a new agent to be monitored, its not going to work AND will be marked as down for an hour until the proxy grabs the new data. I also don't see the efficiency in setting ConfigFrequency=60.
          Put that on the wishlist
          • Alexei
            Founder, CEO
            • Sep 2004
            • 5654
            Well, what happens if the agent is not known to ZABBIX? It would trigger configuration refresh forever...
            Alexei Vladishev
            My Twitter
            • bbrendon
              • Sep 2005
              • 873
              I have an answer for everything...
              Just ignore the agent if the proxy doesn't find a reference in 3 tries.
              • exkg
                • Mar 2007
                • 718
                It's ok but ....
                Alexei,
                Actually (I undesrtood that) zabbix_agentd ask for active itens to first server in 'Server" (directive in zabix_agentd.conf).
                If we change proxy to monitoried hosts we need change 'servers order' in zabbix_agentd.conf to get active checks working.
                Is it a feature or a bug ?
                []s,
                Luciano
                Luciano Alves
                www.zabbix.com
                Brazil | México | Argentina | Colômbia | Chile
                Zabbix Performance Tuning
                • richlv
                  • Oct 2005
                  • 3112
                  zabbix agent always asks first server in the option "Server" for active item list.
                  thus if you want for the agent to ask & report to a proxy, proxy ip must be the forst one specified in that parameter.
                  edit : forgot to mention that it "works as expected", thus in your terminology it's a feature
                  • exkg
                    • Mar 2007
                    • 718
                    OK but ...
                    If we have two or more proxies and want switch hosts between this proxies ... we need change 'zabbix_agentd.conf' too. It's expected ? Sounds bad if zabbix_agent ask for all 'servers' about active items ?
                    []s,
                    Luciano
                    Luciano Alves
                    www.zabbix.com
                    • richlv
                      • Oct 2005
                      • 3112
                      as i noted, it should ask only the first server (and only if active checks are enabled, of course).
                      • NOB
                        • Mar 2007
                        • 469
                        Originally posted by exkg
                        OK but ...
                        []s,
                        Luciano
                        Just use virtual IPs and you're all set.
                        And you need to change the config just for the active checks.
                        If the agents are configured right they'll allow access from all
                        zabbix servers (for passive checks).
                        Just put the real IP addresses of your proxies
                        after the first one in the same text line of zabbix_agentd.conf.
                        Edit: Don't change the implementation. It's OK for now.
                        What would be an idea is to use broadcasts to find the zabbix server.
                        HTH,
                        Norbert.
                        Last edited by NOB; 13-10-2009, 13:22. Reason: Add the proposal to use broadcast to find a ZABBIX server in the network.
