Web monitoring not working
  • colin7151
    • Oct 2006
    • 9
    I created a very simple web monitor that just has one test that goes to a page and looks if there is a 200 status code.
    In the Monitoring -> Web section it lists the test and the Step. It lists a recent time for the last run and that it is idle until 60 sec after that time. The times update and make it appear that everything is working. It even lists the status as OK.
    However when I click on any of the steps I get no data (IE the graphs say "no data" in them. does anyone have any thoughts as to why this is or what I should check ?
    Thanks !
  • colin7151
    • Oct 2006
    • 9
    Figured it out. I had the test attached to a template and not a host. Once I created the test for a host then everything worked fine.
