error in "export import" after converting to node system.
  • neoyagami
    • Jan 2009
    • 13
    hello
    before i convert to node system
    (zabbix_server -n1 -c configfile.conf)
    i can export and inport w/out probem. but now i get this
    * Critical error. Incorrect value for [config] = '100100000000001'
    when i enter to.
    http://zabbix.netglobalis.cl/exp_imp.php and just that.
    i hope you can helpme.
    greetings.
  • Aly
    ZABBIX developer
    • May 2007
    • 1126
    add ?config=1 to the end of the url, problem should disappear.
    http://zabbix.netglobalis.cl/exp_imp.php?config=1
    Zabbix | ex GUI developer
    • neoyagami
      • Jan 2009
      • 13
      tanks.. i will try it in my job the monday :P
      greetings.
      • neoyagami
        • Jan 2009
        • 13
        that do the trick
        thanks
