SNMP polling from specified SourceIP
  • mschlegel
    • Oct 2008
    • 40
    When Zabbix goes to perform an SNMP poll, it is binding the receive port to this virtual IP, as it should. However, when it sends the request to the switch, the request is being sent using the hosts primary IP, instead of the virtual IP specified in SourceIP. Thus, the request gets to the switch, and the switch responds, but zabbix never hears the response.
    tcpdump output:
    16:51:19.090918 IP 172.29.252.2.38208 > 192.168.255.240.snmp: C=gxtro GetRequest(28) .1.3.6.1.2.1.1.2.0
    16:51:19.092339 IP 192.168.255.240.snmp > 172.29.252.2.38208: C=gxtro GetResponse(37) .1.3.6.1.2.1.1.2.0=.1.3.6.1.4.1.9.1.896
    16:51:19.092357 IP 172.29.252.2 > 192.168.255.240: ICMP 172.29.252.2 udp port 38208 unreachable, length 87
    strace of zabbix_server process doing poll:
    socket(PF_INET, SOCK_DGRAM, IPPROTO_IP) = 6
    getsockopt(6, SOL_SOCKET, SO_SNDBUF, [25769930752], [4]) = 0
    getsockopt(6, SOL_SOCKET, SO_RCVBUF, [25769930752], [4]) = 0
    bind(6, {sa_family=AF_INET, sin_port=htons(0), sin_addr=inet_addr("172.29.252.1")}, 16) = 0
    sendmsg(6, {msg_name(16)={sa_family=AF_INET, sin_port=htons(161), sin_addr=inet_addr("192.168.255.240")},....) = 42
    select(7, [6], NULL, NULL, {0, 999996}) = 0 (Timeout)
    Is anyone else successfully using SNMP with a configuration using SourceIP?
    Zabbix version 1.6
    net-snmp-config --version
    5.3.1
  • mschlegel
    • Oct 2008
    • 40
    Has anyone ran into this? I am seeing the same behavior with 1.6.2 as I did with 1.6. This is running with net-snmp v5.3.1-24 rpms for centos 5.
    Any ideas on troubleshooting would be helpful.
    Thank you.
    • tekknokrat
      • Sep 2008
      • 140
      I have the same issue, perhaps you can also give last answer a try:
