Disable Dashboard/reports
  • andydouth
    • Feb 2006
    • 18
    I have a user who has R/O access to a host group - this is all good, however in the dashboard when they login they can see the status of zabbix and in reports they can also see global zabbix items in status of zabbix.
    Is there a way of disabling these, for certain users?
    thanks
  • krisdv
    • Apr 2008
    • 9
    Did you find the answer already? Would like to do this for some users too.
    Regards.
    • NomenNescio
      • Jan 2009
      • 70
      krisdv,
      Did you maybe find the answer to this? I'm having the same problem.
      • krisdv
        • Apr 2008
        • 9
        Unfortunately not. If someone found a workaround please share.
        • NomenNescio
          • Jan 2009
          • 70
          Could someone answer this question please, I'd much rather know that it's not possible than not know if it's possible.
          • NomenNescio
            • Jan 2009
            • 70
            Bump, Can't anyone answer this? It doesn't seem like a difficult question.
            • Aly
              ZABBIX developer
              • May 2007
              • 1126
              Only by manually changing php sources.
              Zabbix | ex GUI developer
              • bada
                • Apr 2009
                How to disable dashboard(Status of ZABBIX)/reports
                First, Modify a "zabbix web directory/include/page_header.php"
                PHP Code:
                                'reports'=>array(
                'label'                 => S_REPORTS,
                'user_type'             => USER_TYPE_ZABBIX_ADMIN,        // modify
                Second, Modify a "zabbix web directory/dashboard.php"
                insert "global $USER_DETAILS;"
                and than
                PHP Code:
                        if ($USER_DETAILS['type'] > 1) {                                                     // insert
                $sysmap_menu = new CDiv(SPACE,'iconmenu');
                $sysmap_menu->AddAction('onclick','javascript: create_dashboard_menu(event,"sysmaps");');
                $sysmap_menu->AddOption('title',S_MENU);
                $left_tab->AddRow(create_hat(
                S_FAVOURITE.SPACE.S_MAPS,
                make_favorite_maps(),
                                        array(
                $sysmap_menu),
                'hat_favmap',
                get_profile('web.dashboard.hats.hat_favmap.state',1)
                // insert
