User Parameter: Syntax changed in 1.6.1 or 2
  • NOB
    • Mar 2007
    • 469
    Hi
    I use a lot of user parameters for the AIX agent because up to now it
    was necessary to even receive the simplest data.
    Up to and including ZABBIX agent version 1.6 the syntax I used was:
    UserParameter=usr.loadavg1,uptime | sed 's/,//'g | awk '{printf $(NF-2)}'
    This worked fine for the 1.4.4 and the 1.6 agents.
    Starting from 1.6.2 - using the same zabbix_agentd.conf file - new error
    messages appear in the logfile of the agent and the agent does no longer start up.
    Error messages:
    1765384:20090123:155215 UserParameter "usr.loadavg1,uptime | sed 's/,//'g | awk
    '{printf $(NF-2)}'" FAILED: Invalid format.
    Obviously, the syntax changed, i.e. I had to quote the statement like:
    UserParameter=usr.loadavg1,"uptime | sed 's/,//'g | awk '{printf $(NF-2)}'"
    Problem: If you have to use quotes inside the statement. You have to use """" (that are four ") for every single " in the statement instead.
    Example:
    " ... | awk '{printf """"%d"""", $ 2}'"
    You have be warned !
    Regards
    Norbert.
  • Sasha
    Zabbix developer
    • Sep 2007
    • 60
    Hello!
    UserParameter syntax changed in version 1.6.1. ... and I rollback this changes in version 1.6.2 rev. 6619 (pre1.6.3). You can download this version from http://www.zabbix.com/downloads/nigh...bix-1.6.tar.gz
    Best regards.
    Alexander Vladishev,
    Zabbix developer.
    ZABBIX Developer
    Riga, Latvia
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      The source of the problem is in incorrect processing of commas. You should have no problems if commas are not used inside the command.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • NOB
        • Mar 2007
        • 469
        Originally posted by Sasha
        Hello!
        Best regards.
        Zabbix developer.
        Thanks a lot.
        Good to know the revision, I already downloaded 6626 for a different reason (malloc).
        Regards
        Norbert.
