ubuntu8.04 and SNMP
  • woger
    • Sep 2005
    • 56
    ubuntu8.04 and SNMP
    Hi there,
    I try to install snmp in zabbix, but after ./configure I get this error:
    checking whether libcurl is usable... yes
    checking for curl_free... yes
    checking for net-snmp-config... /usr/local/bin/net-snmp-config
    checking for main in -lnetsnmp ... no
    configure: error: Not found NET-SNMP library
    I have installed net-snmp from source and the links in the dir are also available:
    $ /usr/local/bin/net-snmp-config --libs
    -L/usr/local/lib -lnetsnmp
    lrwxrwxrwx 1 root root 24 2009-02-01 18:26 libnetsnmpmibs.so -> libnetsnmpmibs.so.15.1.2
    lrwxrwxrwx 1 root root 24 2009-02-01 18:26 libnetsnmpmibs.so.15 -> libnetsnmpmibs.so.15.1.2
    -rwxr-xr-x 1 root root 3156599 2009-02-01 18:26 libnetsnmpmibs.so.15.1.2
    Do I need to install other software an where can I find that? I can find the, in other threads, mentioned net-snmp-devel and tcpd-devel packages.
    Thanks,
    Roger
  • woger
    • Sep 2005
    • 56
    Ok, tried several things and after adding libsnmp-dev package, zabbix installed without a problem.
    Roger
