Zabbix queue refresh problems
  • harez
    • Feb 2009
    I've a problem adding new templates. I've created a new template with different items (system.run[cat FILE] very easy). When I assign this template to a existing or new host it stay in queue forever with a curious date 01.01.1970 01:00:00 and this item is never checked.
    On the other hand some triggers aren't been activated correctly, I've and SSH check with tcp.port and a trigger that activates a HIGH alarm. If 1 (SSH OK) trigger OK, If 0 (SSH KO) trigger ACTIVE. But when SSH service recover the correct state (1) this trigger continues in ACTIVE state.
    I've checked all things, connectivity, firewalls, network problems, permissions, packet loss,...my zabbix version is 1.6.2, and the server load is OK.
    Do you have some idea?
  • harez
    • Feb 2009
    No ideas??????
