SQL query trouble 1.6.2
  • man
    • Feb 2009
    hello,
    got a trouble with mysql query, when i copy trigger for host group get an error:
    * Error in query [SELECT DISTINCT g.groupid as target_id, g.name as target_name FROM groups g, hosts_groups hg WHERE hg.groupid=g.groupid ORDER BY g.name order by target_name] [You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'order by target_name' at line 1]
    * mysql_fetch_assoc(): supplied argument is not a valid MySQL result resource[/usr/home/zabbix/www/zabbix/include/db.inc.php:519]
    i'm using: freebsd 7.1, mysql 5.1.30, apache 2.2.11_3, php 5.2.8
  • man
    • Feb 2009
    problem solved.
