False alarms
  • HEMA1
    • Jun 2008
    • 33
    False alarms
    False alarms
    A trigger fires “process is down” even if the process is up and running? (this does not happens frequently) My thinking is
    that there is a timer value some where that times out? That causes this kind off false alarms.
    Is there any one that has any experience regarding this issue?
    using zabbix server 1.4.6
  • richlv
    • Oct 2005
    • 3112
    check item history. are all values really reporting that process is running ?
    i haven't heard or experienced such a problem with 1.4.6.
